Hallo,
Is it possible to delete a window in a page or even drag drop a window to another page in Hypergraph 14.0?
Thanks in advance,
Prajval Rao
Hi Prajval,
The direct option to delete window in HyperGraph has been removed.
Please follow the workarounds below to delete a window.
Method 1: (1) Swap windows around to put the window that is not needed as the last window on that page (ex. window 4 on a four-window page).
(2) Change the layout of that page from a 4-window layout to a 3-window layout.
Method 2: (1) Create a new page with 3 windows. (2) Copy and paste the windows of interest from one page to another using Edit --> Copy Window / Paste Window in HyperGraph.
Hope this helps.
