Hello!
I am getting in varius size and stack optimization runs the message ERROR 222:
'Error writing record into direct access file - unit number 80.'
Can anyone help me with this? What is the case of the error?
Thanks a lot
Ok solved!
Problem is cause from insuficient disk space! Guess I've burned it out a little!!! :-)
If i found this problem too . How to cal . Down size mesh or somethings else ?
Hi @sagpichest
If you want to downsize the mesh, you may have to remesh part or complete model, recreate boundary conditions, etc...
otheway is to define temporary directory for scratch files
