i have to do a simulation in acusolve for external aerodynamic of a rear wing of a race car
but i didn't find any tutorials of the argument
does anyone know about basic tutorials on acusolve for external flow?
You will have a create some boundary box like below:
I think this tutorial will be helpful:
thx for the replay but in this tutorial the results came from the virtual wind tunnel..
but i want to create the entire study in acusolve
how can i setup all the conditions? i m looking for a basic tutorial for external flow
Hello ppe1906,
What I would do is, import the model in hypermesh, create a boundary box accordingly to the conditions, do a 2d surface mesh in hypermesh for all the geometry (model and boundary box), export the mesh as .arm or nastran format, and do a 3D volume mesh in acusolve, apply different boundary conditions in acuConsolve and solve.
I will share if I find any tutorials.
I found this external flow tutorial following the method I mentioned above.
hello livillyle
i really appreciated your information and this tutorial
thank you so much
There are couple of tutorials in the latest version of AcuSolve that have external aerodynamics for Airfoil.
i tried to open the links but they doesn't work
can u try to replace them?
Oops they were hard coded with my installation folder.
If you open AcuConsole and go to AcuSolve help, you'll find these tutorials. Every AcuSolve installation has these.
There is a PDF document in the installation folder \doc with all tutorials.
i can t find these tutorials, i tried to open acusolve and go to the help page
and i serch in the folder installation too, but nothing
Are you using Windows or Linux?
