Average multiple curves
User: "Altair Forum User"
Updated by Altair Forum User
i want to average multiple curves into one curve.
I know that u can solve this  with a macro funktion, but i dont have the syntax neither i know wich function i have to select and how to programm it.
Can someone help me out please.
<?xml version="1.0" encoding="UTF-8"?>Unbenannt.thumb.PNG.b22ce91488a5f50524f36f0e4b825406.PNGUnbenannt2.PNG.aac62ac020f6a9adb206012fbd676ef6.PNG
1 - 6 of 61
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    You need to configure MVP toolbar to accomplish this task.PFA executable ,steps to configure :
    Please follow the steps below to configure:
    1.       Unzip the 'MVP_Toolbar.zip' in a directory of your choice   Note: the directory structure must be the same as in the zip file!
    2.       Open the file “<Altair_Home>/hw/.preferences.mvw” (from the Hyperworks install directory) in a text editor
    3.       Insert the following line at the end of the file, I am attaching a sample preference file FYR.
    {mvp_toolbar_dir = '<Path of MVP unzipped folder>/MVP_Toolbar';include(mvp_toolbar_dir + '/preferences_macro.mvw')}
    Averaging video is attached for you reference.
    OP
    Hell Rahul,
    thank you for the fast answer. But i got an error i cant fix.
    The funktion 'resmatcurves' says that my values are out of Range. I attached the Data and the Error Protocol.
    Unable to copy above shared file.Please attach above shared file again.
    My bad, I forgot to share required .mvw and tcl file.PFA same.
    User: "Hung Tran"
    Updated by Hung Tran
    Hi mr. Rahul,
    I can't download your file, it is not found.
    Please re-attach this file.
    Thank you very much !!
    User: "Adriano_Koga"
    Updated by Adriano_Koga
    Just to make everyone aware that these kind of multiple curve operation no longer needs MVPToolbar.
    They are available in the core product itself.
    Just select all your curves and RMB.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.6b6bf4f5c7571c86db76040bc0e5e034.png
