Need Help, Probably Doing Something Simple Wrong
User: "Altair Forum User"
Updated by Altair Forum User
Hello I'm new to using hyperworks and have been thrown in the deep end. I took over for a PHD's paper whilst he is on holidays. I have been given a model that im trying to get to run in radioss, but says 'Process encountered an error' 'Run Number too Big'
I'm hoping this means something to someone but I will go through what I was told to do and maybe some one can pick up on what I'm doing wrong.
I was give the model by the Doctor before he left with little instruction so this is what I did.
The file is to simulate a train smash into a wall. A rigid wall has been placed in front of the train.
1. Opened the file
2. Went to Utility -> Bc manager-> Inputs
Name V20
Grinod Parts selected all parts
Initial Velocity
Entered in Velocity
Then created it
3. Created a Memory- Tools -> Creat Cards -> Control Cards -> Memory-> Nmots 75000, Real 0 ***** (could be wrong, unsure)
4. Utility -> Engine File
T- 200
Time Freq- 0.01
Anim Top left and bottom right box checked.
Top left output-
Elem Epsplastic
Elem Vonm Stress
Elem HourG
Bottom Right output
Vel
Cont
Fopt
5. Export Document.
6. Open on Radioss takes about 10 seconds.
a few lines of C:\Altair\hw10.1/hwsolvers/bin/win32/hwsolver.bash: [: -lt: unary operator expected
it then says ---- Run number too big
Process encountered an error.
There is no radioss logo, which means I have missed something that is esstenial to simulate it.
Hope there is enough information to diagnose my problem, if not I have taken some screenshots that I can email (was trying to put up on this forum but had no luck).
Thanks in advance,
Matt
1 - 1 of 11
    OP
    Hello I'm new to using hyperworks and have been thrown in the deep end. I took over for a PHD's paper whilst he is on holidays. I have been given a model that im trying to get to run in radioss' date=' but says 'Process encountered an error' 'Run Number too Big'
    1. Opened the file
    Name V20
    Initial Velocity
    Entered in Velocity
    Then created it
    T- 200
    Time Freq- 0.01
    Top left output-
    Elem Epsplastic
    Elem Vonm Stress
    Elem HourG
    Bottom Right output
    Vel
    Cont
    Fopt
    5. Export Document.
    Thanks in advance,
    Matt
    [/quote']
    Use radioss starter and engine files seperatley, do not use *.bat file, sometimes it does not work depending on the release and update.
    Create your own bat file like:
    'C:\your_altair_dir\hwsolvers\bin\win64\your_starter.exe' -input your_model_starter_file
    'C:\your_altair_dir\hwsolvers\bin\win64\your_engine.exe' -input your_model_engine_file -nproc or-ncpu cpu_count
    Check out the forum for the parallel solution process, I had wrote something about that.
