How should can I transfer my model after topology and size optimization from hyperview to CATIA V5 and again back to Hypermesh after editing the model? Thanks alot in advance
Hi Prateek,
For topology, You can use OSSmooth to export the geometry from HyperMesh. Here is a tip and trick which explains how to use OSSmooth.
http://www.altairuniversity.com/wp-content/uploads/2013/12/1075.pdf
For size optimization, you can import the .prop file into HyperMesh along with the parent model to overwrite the new thickness.
How to export mesh from hyper-mesh to CATIA?
No mesh format in Catia software!
You can export geometry from HyperMesh to CATIA.
If CATIA support .stl you can export mesh to stl file
