*** ERROR # 1000 *** in the input data: Incorrect data in field # 3.
I am an absolute newbie to the software and have received no training on Hyperworks or with any other composite modelling software. I am designing a Monocoque chassis for the Shell Eco Marathon for my third year project and ran into the following error while running optistruct:
There were 6596 error messages during input processing.
The first message is repeated below:
*** See next message about line 7524 from file:
C:/Users/Ashbel/Documents/Altair files/Disso CAD/Final Chassis v1/Final chassis v1.fem
'CTRIA3 1 0 74 87 75 0'
==== End of solver screen output ====
==== Job completed ====
Any help would be greatly appreciated.
Thanks
Hi Prakash,
I tried replacing the file as well as just importing the .fem file as a solver deck, however i get the same error:
Messages for the job:
C:/Users/Ashbel/Documents/Altair files/Disso CAD/Final Chassis v1/Reworked/Final chassis v1 reworked.fem
Run summary:Preserving existing .out file as:
C:/Users/Ashbel/Documents/Altair files/Disso CAD/Final Chassis v1/Reworked/Final chassis v1 reworked_001.out
Preserving existing .stat file as:
C:/Users/Ashbel/Documents/Altair files/Disso CAD/Final Chassis v1/Reworked/Final chassis v1 reworked_001.stat
** OptiStruct 14.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows 8 Workstation (Build 9200) DESKTOP-U09HUCS **
** 4 CPU: AMD FX(tm)-4300 Quad-Core Processor **
** CPU speed 4000 MHz **
** 3695 MB RAM, 11212 MB swap **
** Build tag: 0801293aw733140_Ce64RBW8UH12M:111035-000 4000000004000 **
** COPYRIGHT (C) 1996-2015 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
Incorrect data in field # 3.************************************************************************
'CTRIA3 1 0 74 87 75 0'*** ERROR # 1000 *** in the input data:
************************************************************************==== End of solver screen output ====
0 -
Ash,
Are you usign HW student Edition?
0 -
Yes, its the student version.
0 -
Ash,
I am able to run the .fem file in 14.0 SE without any modifications. Make sure Import is set to all under Import Solver deck options.
HyperWorks 2017 Student Edition is out, please update.
0 -
Hi Prakash,
I have 14.0 version of the Student Edition. I assume this is the 2017 version.
I have ensured that the import option is set to all, however i appear to have the same error. An image of this is attached to the post.<?xml version="1.0" encoding="UTF-8"?>
The software once did state that the graphics card may be unsupported, could this issue be causing the problem?
If this is the case could I import the .fem file to abaqus? as i have access to it at university
0 -
The file seems to be finally work.
Thanks for you help. It is much appreciated.
Ash0
