ERROR 760
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
I am running front impact analysis of a truck frame, and my simulation is not working and I am getting Error 760. The card image for the components are parts. Can someone tell me what could have gone wrong.
I have attached the hm file. Please let me know if something is wrong.
Thank you very much.
  • harshitpuri
    harshitpuri Altair Community Member
    edited May 2016
    Can you attach the out file
    starter out file seperately.
    _0000.out
  • Altair Forum User
    Altair Forum User
    I have attached the .out file. Thank you very much.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited May 2016
    I believe you have some modelling error. please check same in model checker.
  • harshitpuri
    edited May 2016
    the problem lies in interface .
  • Rahul Rajan_21763
    edited May 2016
    yes the problem is with gap which is clearly mentioned as warning in the out file. I see you have intersection & penetration in your model.please remove & run.
  • Altair Forum User
    Altair Forum User
    edited May 2016
    Thank you very much Rahul and Harshitpuri. Can you please tell me what is wrong in my interface. Is the type 7 wrong?  If type 7 is right what are the mandatory fields in that card I should enter so that it should work?
  • Rahul Rajan_21763
    edited May 2016
    Refer this video for Type 7 contact.
    https://altair-2.wistia.com/medias/0xlcd7hliu
  • Altair Forum User
    Altair Forum User
    edited May 2016
    Reduce the Gapmin value
  • Altair Forum User
    Altair Forum User
    edited May 2016
    I did the change and edited the interface. Now I am getting an error in Rigid bodies. Error 442 (Error in Rigid Body Definition). I am not able to understand what error that is. Can someone please help me.
  • Altair Forum User
    Altair Forum User
    edited May 2016
    Recheck the rigid bodies created.
    Don't assign any material/property to the rigid body. And don't assign any card image to rigid body
  • Altair Forum User
    Altair Forum User
    edited May 2016
    Thank you George for the reply. I have not used any material or property for  the rigid body. I haven't used any card also, it is still showing an error.
  • Altair Forum User
    Altair Forum User
    edited May 2016
    There could be several reasons for this error.
    Can you share the file to check?
    You can use the dropbox link in my signature below to share the file with me.
  • Altair Forum User
    Altair Forum User
    edited May 2016
    It is not recommended to set a node of the mesh as the master node of a rigid body and in this case two rigid bodies are sharing the same master node in several cases.
    And also clear the penetrations in the model.
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Is there any way to check which two rigid bodies share the same master node?
  • Rahul Rajan_21763
    edited June 2016
    Best way is to use Model checker.
  • Altair Forum User
    Altair Forum User
    edited June 2016
    As Rahul mentioned, please use the model checker where the errors and warnings in the model will be displayed. Some of these errors can be auto- corrected while others has to be fixed manually.
  • Altair Forum User
    Altair Forum User
    edited May 2017
    I am also facing Error 760 while simulation.
    model check list is as below.
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Error id 760 is shown when there is a modelling error. In the model checker you can see that a component is missing material. Please recheck the same.
    Please note: If you are a commercial customer, you can also contact your local support http://www.altairhyp...ortProduct.aspx
