Non-dimensionalization of problem
User: "Prabin Pradhananga_22497"
Altair Community Member
Updated by unknown
Hi experts,
I wanted to solve a simple flow over cylinder problem non-dimensionally in acusolve. I understood the theoretical concepts associated with non-diemensionalization. But, I don't know how to implement it in acusolve. Is it possible by just changing the Reynold's number of the flow? If yes, how to do it?
Thanks!
1 - 1 of 11
    User: "acupro"
    Accepted Answer
    Updated by acupro
    Reynolds number = ( Density * Velocity * Length ) / Dynamic Viscosity
    For a given length, you can change the Reynolds number by changing the other parameters, including material properties.  For example, if you set density = 1, velocity = 1, and use a reference length of 1, you can set the Reynolds number by setting the appropriate viscosity value.
    You'll need to create your own fluid material model in order to specify the density and/or viscosity.
