Can i fix 'normal termination error' problem?
when i solve a problem with radioss, i get this message after 14-18 animation file. How can i fix this problem? Or can i rerun my analysis last reset file?
hi,
you could rerun your analysis if you use explicit solver, just add a 'rerun' option into your engine file (i.e. replace 'run' to 'rerun'). error code is important also, if any.
