I try to make a core shift simulation (multiple bodies) in Moldflow with boundary layers. I used the boolean operation to find the common faces and meshed them after this. The nodes look good, I do not see any intersection or failure, but in Moldflow I always get an error: ** ERROR 304717 ** A node has been found which belongs to both a part element and another element which is not in the part. This is not supported. Please check the mesh connectivity and the element property types. Does anybody know, how can I fix this?
Béla
