Viewing Virtual Wind Tunnel results in AcuFieldView
Altair Forum User
I've recently started using VWT and want to open the solver results files in AcuFieldView but don't seem to be having any luck. I've searched through the help PDF's but couldn't find any information as to how to import results files or even what files format it should be in.
Any help?
Thanks,
Mike
Use File > Data Input > AcuSolve Direct Reader
Open vwtAnalysis.Log or any AcuSolve log file with that.
0 -
I could open the data using Use File > Data Input > AcuSolve Direct Reader, but I cannot see the streamlines. How can I do it? I have tried until now so many ways and unfortunately nothing happens.The simulation is ok, I obtained the vwtAnalysis.pdf with the Drag coefficient, Lift coefficient, etc.Could you please explain step by step what I should do?0
Please check the help under similar path in your installation. There are step by step instructions to generate streamlines.
/HW13/acusolve/win64/help/acu/AcuSolveTOC.htm?working_with_transient_data.htm
(This can be accessed by AcuConsole > AcuSolve Help Home).
