How to get contact force graph in radioss
create an output block selecting groups from the menu and select the interfaces from which you want the plots.
once output block is created edit it and input DEF in variable field which will provide all normal and tangential forces in X Y Z direction
sir please to where and how to select the interface,sir please its urgent
Go to Analysis tab>> Output Block>>Give a name and select group from the drop down menu>> click the group and select the interface.
see attached images
thank you sir, sir i more thing how do i see that graph in hypergraph
upload the T01 file in HyperGraph. and find the attached image for further steps
thank you sir
I have a question.
What is the difference from the contact force in hyperview and in hypergraph?
In hyperview we have the contact force in all points of a shell but in hyper graph 2D we only have one value.
Is the value in hyper graph 2D the sum of all in hyperview?
Thank you
In HyperView the contact forces are extracted for the whole model whereas in HyperGraph we are separately extracting the contact forces from the interfaces defined.
Hi
So is it the sum of all stress x area in the interfaces?
The relation for contact force depends on the magnitude of mass of the body and the sudden change in velocity of the body, which is acceleration. If the system of objects is not accelerating, then the contact force between the bodies is just the initial force. There are many open web resources available on calculating contact forces and I request you to go through those for better understanding of this concept.
