Hello
I am making a topology optimization for a rotational disk that rotates under 4500 RPM. It should be just free in radial direction. I always see the same error shown below. How can I solve it. I read all previous comments about the same error. Most it said that it can be because of my constraints. Although I change my constraints it gives the same error. Can anyone help me for that.
Thank you in advance
In static load case 1
the compliance is negative or large 1.77994e+020.
Optimization/buckling analysis cannot be performed.
due to possible rigid body mode.
