what material property are required for fatigue analysis ?
hi,
It depends on the method of fatigue analysis you are opting for like S-N method etc.
For S-N method, you need S-N curve property of the material and can also use some empirical relations certain fixed parameters required for such analysis.
It is given in optistruct help
Actually there is a lot you can input provided what you have.
I would suggest you to refer fatigue theory available on OptiStruct help and also tutorials.
hi, It depends on the method of fatigue analysis you are opting for like S-N method etc. For S-N method, you need S-N curve property of the material and can also use some empirical relations certain fixed parameters required for such analysis. It is given in optistruct help
if i do not have SN CURVE DATA what i can do ?
Hi @ank
What data do you have so far?
density,yield stress,ultimate stress,young modulus,poisson ratio.
hi every one, im new member !
I have no experience in fatigue analysis .
Could any one teach me how to set all condition for this analysis plz.
Thanks any way !
my mail is : hoangdaitnut@gmail.com
Please download free eBook on Fatigue analysis using Optistruct.
https://altairuniversity.com/free-ebook-learning-fatigue-analysis-with-optistruct/
Please download free eBook on Fatigue analysis using Optistruct. https://altairuniversity.com/free-ebook-learning-fatigue-analysis-with-optistruct/
Thanks for your answer !
I am reading the e-book follow your suggestion.
Now, i dont have SN or EN data.
so i wonder how can i setting material properties or evaluation for my analysis ?
can u explain me more a bit plz.
thanks for your kindly help !
