I want to get Time vs Temperature data at a point in my casting simulation to predict the microstructure and to plot the Time vs Temp. graph. Is there any way to get this data from the simulation results in an csv file??
Hello Priyanshu,
You can create a sensor in certain locations using the latest version of Inspire Cast. This will allow you to find values over time at the sensor location like call-out points. Then you can open the call-out table and simply copy and paste the time vs temperature data from Inspire Cast to your Excel sheet.
Milan Raval
