In post processing, for inlet or outlet surface i can see the magnitude of pressure with good color spectrum, but Is there any possibility to get integrated value of pressure or velocity on that surface
It is possible to do that with AcuProbe.
Surface Ouput > Surface
Hello sir, Thank you but I can only access to these parameters but Acusolve can not do for quantities like kinetic energy. So I came up with a script formula to find kinetic energy. In FV I processed it and want to know the integrated value of kinetic energy. When I switch on the color map I see color spectrum as well as title showing Kinetic energy. I am surprised there is a value below it. Does it represent the integrated value, or it is not related to it.
Once you have the surface contours you desire, you can use the Integration tool to integrate the current surface. 'Integrate' from left side icons or Tools > Integration from the top bar.
Thank you very much sir. I just want to ensure one more thing. I am new to Acu FV. I just know how to see along coordinate surfaces of a model. can you tell me how can I see my kinetic energy over whole model.
