Ho to combine several load step in an analysis
Hi
I am doing FRA analysis using optistruct. I have 3 differenet load steps for X, Y and Z direction. I want to see the results of all these 3 load steps in Hyperviw and do a superposition. I have defined all my load steps in Optistruct but the analysis goes only through the first load step and the result created are only for that load step. I don't know how can I have all these 3 load steps in one run. Thanks for your help in advance.
Hi Prakash
Thank you very much for your help
Attached is the .out file. I am gonna try the file you have attached and let you know
0 -
Hi Prakash
Your model shows the results for both subcases Is there any way to see the result for combination of these two sub cases? doing a kind of super position for displacement for instance.
0 -
You can use DLOAD to combine dynamic loads.
