HI,
I would like to know the properties of the quasi-isotropic CFRP laminated composite laminate to have such properties.
This CFRP is orthotropic material.
| Elastic modulus in fiber direction | E11 | 131GPa | | Elastic modulus in transverse direction | E22 | 8.2GPa | | Elastic modulus in transverse direction | E33 | 8.2GPa | | Shear modulus in 1-2 plane | G12 | 4.5GPa | | Shear modulus in 1-3 plane | G13 | 4.5GPa | | Shear modulus in 2-3 plane | G23 | 3.5GPa | | Poisson's ratio | v12 | 0.281 | | Poisson's ratio | v13 | 0.281 | | Poisson's ratio | v23 | 0.47 | | Tensile strength in fiber direction | σt11 | 2000MPa | | Tensile strength in transverse direction | σt22 | 61MPa | | Compression strength in fiber direction | σc11 | 1400Mpa | | Compression strength in transverse direction | σc22 | 130MPa | | Shear strength in 1-2 plane | τ12 | 70MPa | | Shear strength in 1-3 plane | τ13 | 70MPa | | Shear strength in 2-3 plane | τ23 | 40MPa |
Order stack the CFRP is 0 ° 90 ° 45 ° -45 ° -45 ° 45 ° 90 ° 0
And to obtain the properties for MAT25 type (in Radioss) of CFRP.
Material properties for MAT25 are E11, E22, E33, Nu_12, Iflag, G12, G23, G31, EPS_t1, EPS_m1, EPS_t2, EPS_m2, Wp_max, Ioff, Ratio, SIG1_yt, b1_t, n1_t, SIG1max_t, SIG2_yt, b2_t, n2_t, SIG2max_t, SIG1_yc, b1_c, n1_c, SIG1max_c, EPS1_c1, EPS2_c1, SIG2_yc, b2_c, n2_c, SIG2max_c, EPS1_c2, EPS2_c2, SIG12_yt, b12_t, n12_t, SIG12max_t.
Please show me how to know this properties.
