How to draw bolt pretension in HyperGraph
Altair Forum User
Altair Forum User
I use the Optistruct and I have the <filename>.pret file
When I try to input file in Hypergraph, it can not show the time to plused force curve.
At here my time is 1 sec and my pretension force is 6000N.
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.590e9963dc5e7a38d97c8e8763ad9584.png
Here is my file ↓
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited April 2018
    As an alternate option, please request OLOAD output (along with NLOUT), then you can plot the applied forces (pretension force at the SPOINT node) from h3d file.
  • Altair Forum User
    Altair Forum User
    edited April 2018
    @Rahul R Thanks for your reply!
    Because it doesn't show notice so I reply lately, Sorry.
    Here I have choose my node at HyperGraph 2D.
    And I have set the OLOAD at my fem file.
    But when I plot in HyperGraph 2D, it doesn't show my applied pretension force at the plot.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.ca950516532bb4b7af1ab38591960339.png
    Here I upload my fem file.
  • Rahul Rajan_21763
    edited April 2018
    You need to plot the pretension force at the SPOINT node, only then will it give the pretension force. You can get the SPOINT node id from your pret file or out file.
  • Altair Forum User
    Altair Forum User
    edited April 2018
    @Rahul R Thanks to your apply!
    I have the same picture like you. And I use the same SPOINT with you.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.31d712794a68d7b006b051ac45df08e3.png
    here I can get the SPONT ID from my pret file and out file it also the same.
    Really thanks to you.
  • Altair Forum User
    Altair Forum User
    edited April 2018
    @Rahul R Sorry I have another question about if today I want to output the force of a surface.
    Not the pretension.
    How can I do at the H3D file in HyperGraph
    How Can I do? Like this photo
  • Rahul Rajan_21763
    edited April 2018
    If you want to get reaction forces using OptiStruct, then please add SPCF anf GPFORCE cards from Analysis page>> Control cards>> Global output request.
  • Altair Forum User
    Altair Forum User
    edited April 2018
    @Rahul R Thanks to your reply!
    I have set the SPCF and GPFORCE like this
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.1b7f7f1c863a99d6b2d9e88b47e07a32.png
    At here I can't find GPFORCE format for h3d, but when I see help it can set in h3d
    And If I choose nodes to output the values it looks strange
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.b045927311cbe7b6d326e9f9141e215c.png
    Here I have my h3d.file and fem.file.
  • Rahul Rajan_21763
    edited November 2020
    To get the forces (for specific nodes) , can you try using the FBD tool in HV. You would need to have an op2 result file to visualize the same. You could even punch out the forces as a csv file.
    I am attaching the relevant document FYR.
  • Altair Forum User
    Altair Forum User
    edited April 2018
    I have set to op2 for GPFORCE
    But when I choose Results>Plot>FBD. At here I input the op2 file.
    it will show
  • Rahul Rajan_21763
    edited April 2018
    Please make sure to load the result file with Advanced result math template option in HyperView.
  • Altair Forum User
    Altair Forum User
    edited April 2018
    @Rahul R Thanks to your reply.
    I have opened the HyperGraph2D successfully
    At here I can't select the sum points of circle, I just can choose one node.
    <?xml version="1.0" encoding="UTF-8"?>1.thumb.JPG.98bf1add2e4ff844673275d18e88cb93.JPG
    Can I do that?
    And when I choose Apply in FBD plot it can't plot.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.190abf55b85be7e80b7b99c1edaf4692.png
  • Altair Forum User
    Altair Forum User
    edited April 2018
    LKZ
    Please follow the below steps.
    <?xml version="1.0" encoding="UTF-8"?>Capture.thumb.PNG.619488977bfcec09b019896c59a35a49.PNG
    With the Pick: Elements selector active, pick the elements on which you want to plot. (for example as shown in the above image). Then, add those elements to FBD section (Click +).
    Assign the system to it. then pick a node where you want the forces to be plot. Then, click apply.
    Select the load case and then, you will be able to see the FBD plots. Also, you can see the values when you click on the highlighted icon.
    Thank you
  • Altair Forum User
    Altair Forum User
    edited April 2018
    @Premanand Suryavanshi Thanks to your reply!
    Because I have tried that I can output the pretension force.
    And it can output but I can't draw it pretension with time curve.
    Do you know where is my wrong?
    image.png.5291f1ec74cc0933114a59e462be773b.png     image.png.3a1f0e93b0ef87487d3ff090cd1a1049.png
    I can export my node total force and it is the same.
    I now have the problem because my op2 result just to show the last step result.
    It doesn't have process so how do I show the time to pretension curve.
  • Altair Forum User
    Altair Forum User
    edited May 2018
    Hi
    Sorry for late reply. I was on vacation.
    The applied force or the pre-tension force has to be incremental in order to plot the curve. I your case it is showing only the final load/result
    Thank you
