Dear all
I am using NLGEOM method to solve a nonlinear problem. I want to use discrete date to define material. And the first (x1,y1) are (0, 310), 310 is the initial yield point.
But when I analysis, there comes a problem. The following shows the problem.
*** ERROR # 3002 ***
The first point (X1,Y1) specified on the TABLES1 bulk data entry ID=5
is not located at the origin of the stress-strain curve.
I don't know why, could you help me with that? The model I used is as follows. Thanks!
