Error 153
Altair Forum User
Altair Forum User
 *** ERROR # 153 ***
 Exactly zero pivoting encountered during Numerical Factorization;
 the model may have rigid body mode.
  Solver error no. =   -503
        spc set id = 3
             index =      1
 Possible reasons are:
 1) insufficiently constrained model,
 2) having rigid body mechanisms within the model,
 3) extremely ill-conditioned rigid element sets,
 4) extremely thin shells (as used for skinning) that have MID2/MID3,
 5) gap elements with extremely high stiffness (KA, especially KT or MU).
 Check the model and rerun the problem.
 (MECHCHECK may be used to find the rigid body modes.  To do so,
  change the input to be an eigenvalue analysis and add MECHCHECK.)
 (WARNING: results obtained with MECHCHECK cannot be used because
          the model is changed internally.)
 This error was detected in subroutine bcsmtxfct.
  • Altair Forum User
    Altair Forum User
    edited April 2017
    Hi Ramesh,
    The error could be because of insufficient constraints in your model.
    It is recommended to run the model with MECHCHECK and (or) GROUNDCHECK option in normal mode loadstep to detect the massless mechanism where the massless mechanism will show up as rigid body modes ( This run should be considered as a step to debug the problem as the results from this solver is inaccurate)
    If possible share the model file.
