Hi
I have a question regarding the contact forces results.
I am not sure these contact forces in Hyper view demonstrate what.
I have done a simple nonlinear analysis
Pressure is applied on the core cap
and 6 bolt forces each one equal to 120 KN as shown below
and this bottom surface is constrained fully
The follwing is the results I got for the contact forces
Contact forec on the core cap piece, 4.58 E3 N
Contact force on the core piece 8.9E3 N
I don't understand why these two numbers are not equal. They are action and reaction forces. contact force here in this problem is internal force right? so the amount of force that core applies to the core cap should be equal to what core cap applies to core just in opposit direction to have equilibrium
Even if I consider core cap only and write the equilibrium equation for that
bolt force + Normal contact force applied the core cap is not equal to pressure* cross area which is weird
i appreciate if you can explain me what these contact forces really are in Hyperview.
