To mambers,
I have a problem when running (error ID 760).
Hi Muhammad,
can you share the entire starter out file?
Make sure you have assigned the /PART image to all components.
Hi Mr. Prakash
Thank you for the advice, now my problem is estimated time running not appear (I use HW.12) and how to resolve the warning in my case.
Can you give advice?
.. BLOCK FREE FORMAT .. STARTER RUNNING ON 1 THREAD .. CONTROL VARIABLES .. UNITS SYSTEM .. FUNCTIONS & TABLES .. MATERIALS .. NODES .. PROPERTIES .. 3D SOLID ELEMENTS .. 3D SPRING ELEMENTS .. SUBSETS .. ELEMENT GROUPS .. PART GROUPS .. SURFACES .. NODE GROUP ** WARNING IN NODE GROUP DEFINITION .. BOUNDARY CONDITIONS .. CONCENTRATED LOADS .. DOMAIN DECOMPOSITION .. ELEMENT GROUPS .. INTERFACES ** WARNING : INITIAL PENETRATIONS IN INTERFACE ** WARNING : INITIAL PENETRATIONS IN INTERFACE .. RIGID BODIES .. RETURNS TO DOMAIN DECOMPOSITION FOR OPTIMIZATION .. DOMAIN DECOMPOSITION .. ELEMENT GROUPS .. INTERFACES ** WARNING : INITIAL PENETRATIONS IN INTERFACE ** WARNING : INITIAL PENETRATIONS IN INTERFACE .. RIGID BODIES .. ELEMENT BUFFER INITIALIZATION .. GEOMETRY PLOT FILE .. PARALLEL RESTART FILES GENERATION TERMINATION WITH WARNING ------------------ 0 ERROR(S) 5 WARNING(S) PLEASE CHECK LISTING FILE FOR FURTHER DETAILS ==== End of solver screen output ====
Thank you
please correct all the penetrations in the model. you can do it in hypermesh or you can use hypercrash for that, which is more easy.
What type of analysis you are doing ?.
