Division of curves
Altair Forum User
Altair Forum User
I have created a curve of acceleration Vs frequency as well applied load Vs frequency.
But actually my aim is to draw a curve of accelerance (acceleration/ force) Vs frequency.
I think it can be done using division operation (math curve)
But don't know how to apply?
Does anyone knows much about this, please help me.... image/emoticons/default_sad.png' alt=':(' srcset='<fileStore.core_Emoticons>/emoticons/sad@2x.png 2x' width='20' height='20'>
<?xml version="1.0" encoding="UTF-8"?>post-37323-0-45092300-1443521944_thumb.p
<?xml version="1.0" encoding="UTF-8"?>post-37323-0-10127200-1443521945_thumb.p
  • Rahul_P1
    Rahul_P1
    edited September 2015
    To divide two curves,
    File > load > vehicle safety tools > then go to math in the menu > two curves math > divide > select the numerator and denominator,
    Use divide by zero if necessary for your case, i.e. if c1 is divided by c2, and if c2 has any zero values, then c1/c2 equals 0.
  • Altair Forum User
    Altair Forum User
    I am not sure whether my process is right or not.
    The curves I plotted using build plots.
    I separated the window in to 4, 3 of the window I used for HG.
    So in 2nd window I have acceleration plot, 3rd I have load.
    And now from the 4th window if I am going for vehicle safety---math---divide its not coming the selection window for numerator nd denominator.
    But without any plot I tried, in that case the numerator denominator selection window is coming..
    So what will be my mistake?
  • Altair Forum User
    Altair Forum User
    Is there anyone is to help me???? image/emoticons/default_unsure.png' alt=':unsure:'>
  • Rahul_P1
    Rahul_P1
    You will have to use XY plots and not the complex plots ( phase and magnitude )
    So plot your data as a normal XY plot and then use divide function,
