Hello guys.
I am trying to model an impact between to bodies. I have modelled the impactor/projectile with solid elements using MAT1 and steel as material and i am trying to model the target plate as a composite shell with either MAT15 or MAT25. The simulation goes fine, no errors or anything like that but the results are simply non physical, in my opinion at least. It appears as if the target plate has no stiffness at all and it behaves like a piece of cloth.. I just cannot figure out what is going wrong. I am attaching 2 images from the simulation setup and results. If anyone needs more info i can happily provide it.
P.S. I am using RADIOSS BLOCK 110, HW12.0, interfaces are of type 7 if thats of any importance. The plate is sitting on a rigid body with a square hole in the center, ofc an interface is modelled between the 2.
