Hi experts,
I was going through AcuSolve tutorial ACU-T: 5403 Piezoelectric Flow Energy Harvester: A Fluid-Structure Interaction. But I could not launch OptiStruct. The following error messages are displayed.
What could be the reason?
Thanks.
Hi Prabin Pradhananga,
Did you install the Mechanical Solvers 2022 and the hotfix Mechanical Solvers 2022.0.1?
If you haven't installed them, you can download them from Mechanical Solvers 2022
Best regards,
Alexandru
Hi Prabin Pradhananga, Did you install the Mechanical Solvers 2022 and the hotfix Mechanical Solvers 2022.0.1? If you haven't installed them, you can download them from Mechanical Solvers 2022 Best regards, Alexandru
Oh, I haven't installed them. Thank you for your help.
You’re Welcome!
