About master and slave SLIDE contact
hello everyone
I am performing Slide contact between the pin and plate forming the revolute joint. in radioss
initially i have performed analysis with pin as MASTER and that plate with SLAVE found ans with stresses at about 200mpa
then i changed the combination with pin as SLAVE and plate as MASTER now i am getting results about 10mpa
so why is this drastic differenece????????????
which one is correct??????????/
What type of contact interface you are using?
http://www.altairuniversity.com/free-ebooks-2/free-ebook-crash-analysis-with-radioss-a-study-guide/
link for downloading Free Ebook .(Crash analysis with Radioss)
Regards
Rahul R
0 -
Hi Sagar,
Are you using same material for both master and slave?
Based on the contact stiffness formulation the contact stiffness depends on master and slave stiffness.
0 -
hello first of all thank you all replies
i am using SLIDE interface in contact
and yes i have just changed master and slave rest all is one and same????
0 -
link for downloading Free Ebook .(Crash analysis with Radioss) Here in Type 7 contact interface we talk about master slave concept.
Regards
Rahul R
