hello
i work with composite and above optistruct .I choose the PCOMPP card and i use ply laminate stack.
i have message : element 608 is referenced by multiple STACK cards
thanks for all
can you check if the same ply is used in multiple stacks?
if you still have the problem, please share the file with us using the dropbox link in my signature.
Thank you for yours response, you are right.
hi
after having solved the probleme ,i got this error :http://cjoint.com/?DJEwqPmWYo5
what is a solution please
thank you
Please check the loadstep which you have created. The error says that there is no load referred in the Linear static subcase.
