I would like to optimize the material properties for a PSOLID with a MAT1 material (i.e., E, RHO, GE). For example, I have a solid bar of dimensions 1 x 1 x 1 inch. I want the frequency to be 4000Hz. Instead of changing the size, I want to solve for the MAT1 properties that would yield the 4000Hz. I have tried to use the DESVAR, DVPREL, and DDVAL functions, but it seems that those want to work with PSHELL, not PSOLID.
My model is attached. It is basically a SDOF mass spring system that is fully constrained on one end and constrained in all DOFs except X on the opposite end. I give it an initial condition Xo = 0.25 inch. It runs a direct transient analysis.
Thanks,
Neil Hall, Callaway Golf, 760-822-4794
