I would like to know if it is possible to output the last iteration on a non-convergent solution on a quasi static-case.
Best regards
Hi Vivien,
using NLOUT it should be possible.
Please refer to NLOUT card in OptiStruct.
I forgot to precise that I work with Optistuct v13. I seem that this card doesn't exist with this version.
Vivien,
NLOUT is available from 14.0.
I will check if there is any other way to get the results.
Thanks Prakash
Regards
Vivien
