MBD analysis error by flexible bodies
User: "Altair Forum User"
Updated by Altair Forum User
As soon as I change in an MDB analysis the body properties from rigid to flexible, I got error messages.
I uploded my example models to:   https://ftin.india.altair.com:8443/filedrop/
test_zusammenbau_zyl_2_rbody.fem : all rigids, it's OK
test_zusammenbau_zyl_2_fbody_1.fem:   $HMNAME GROUP                  1'kolben' 'PFBODY', with error
test_zusammenbau_zyl_2_fbody_3.fem     $HMNAME GROUP                  4'pleuel' 'PFBODY'
        $HMNAME GROUP                  3'hebel' 'PFBODY',  with error
Thank you and best regards,
Szilard Balazs
1 - 2 of 21
    OP
    The problem is with the tetra elements. It may not be possible to get corner stress for tria/tetra elements.
    Change it to  center instead and you should be able to run the model.
    My suggestion would be use QUAD/HEXA elements instead of tria/tetra elements and request corner stress.
    Thanks and Regards
    Prakash Pagadala | Altair Engineering
    An another thing is, that each MDB analysis must to run in a separate directory...
    OP
    Thanks for posting the answer image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
