Hi
I have to define material properties (Youngs and shear modulus in all the 3 directions) for the composite solid element.
I have used /PROP/SOL_ORTH card and as far as I know, Radioss defines the element directions relative to the element numbering convention.
Therefore for an extruded solid element for the core properties, t and r represent the in-plane directions and s represents the through thickness direction.
And therefore E11 and E33 are the in plane properties and E22 defines the through thickness properties with the orthogonal angle set to 0.
My question is if there is any other way to check or alter the co-ordinate system while modelling the core?
How would I modify the element coordinate system to replicate the global system?
Thanks
