Hi, I use a student version of hyperworks. When i try to open a geometry cad file .stp into hypermesh the segmentation error is always displayed. And then software closes. I have got student license and activated it as per the manual.
Hi Ameer,
This looks unusual as importing .stp file is supported in HWX. May be you need to reinstall or cleanup up you Document and Temp folder before reinstalling.
I hope you have taken correct installation files.
Thanks
Rajashri
i downloaded and installed student version as well as activated license as per altair manuals. Installation file was downloaded from altair marketplace.license code was received via student mail.
Can you please share a pic of installation files you have taken?
Is it 2023Version?
If you can share the .stp file I can check at my end.
I have the same problem exactly. I even tried different CAD file formats and the segmentation error message keeps popping. Can you please tell me how to fix this? I really need to start working on a part ASAP.
any updates?
Hi Ameer, This looks unusual as importing .stp file is supported in HWX. May be you need to reinstall or cleanup up you Document and Temp folder before reinstalling. I hope you have taken correct installation files. Thanks Rajashri
hi rajashri.
any updates on how to solve this?
Can you please share a pic of installation files you have taken? Is it 2023Version? If you can share the .stp file I can check at my end. Thanks Rajashri
2023 version
please find attached stp file. ( from udemy course , i got this stp file )
installation file i downloaded from altair one marketplace.
i deleted the download file after installing it to free up some space.
Please look through this article. More than likely something about your hardware or graphics system
https://community.altair.com/community/en/altair-hyperworks-hardware-and-system-requirements?id=kb_article&sysparm_article=KB0119809
