Hi ,
after some modifications I made on the bodies, joints I get this error message, and I don't know how to get rid of it, what that really means....
I could not attach the .out file so I copied here the relevant infos from the out file.
Thanks in advance for your sugestions....
Szilard
ITERATION 0
Running MBD subcase 5
Simulation result file name: test_zusammenbau_zyl_kraft_trans_über_rbe2_1_mbd.h3d
NUSolver xml input file has been generated.
*** Begin sending off data
Sending off model unit...
Loading flex_h3d [pleuel.h3d]...
Loading Invariants from H3D file for flexbody [id=5] !
Writing model to [test_zusammenbau_zyl_kraft_trans_über_rbe2_1_mbd.xml]...
*** End sending off data
--- solver log closed on 13-FEB-2015 08:53:13 ---
Error: Cannot open an MBD result file.
This error occurs in module 'mbddrv'.
Delete bootstrap file test_zusammenbau_zyl_kraft_trans_über_rbe2_1.OS_dumpfile_scr.bin
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
OptiStruct ERROR: 997.
A fatal error has occurred in your model. Please refer to the .out
file to obtain more information on how to correct it.
