I want matching mesh between two faces of different component. How to do this in simlab?
Use Assembly ribbon>Connect toolbar>Join option to get matching mesh.
Please, notice that all bodies must belong to the same Model (i. e., the same GDA assembly). You can not join bodies between different models, otherwise you would have duplicate entity IDs. So, first move bodies into the same model.
Please take a look to this tutorial this tutorial (attached) for the joining procedure
