What does the 'SCALE' value mean in 'FATLOAD' keyword?
After referring to some online manual, it was mentioned to maintain a scale factor of 5. It is mentioned in the same manual that certain fatigue load should be applied and that same load has been applied in LOADCOL and the additional scale factor of 5 in FATLOAD. We aren't sure if they are applying 5 times the load mentioned.
Also, what exactly is LDM in the FATLOAD keycard?
