missing white spaces in grid data in exporting mesh
Altair Forum User
Altair Forum User
Hello everyone,
I am having trouble exporting the mesh from Hypermesh. Some white spaces separating the fields are missing.
*)  With the RADIOSS profile, the first three nodes of the grid data look like this.
         1    10.4352852680878   0.374999999999996    1.69690861652916
         2    10.0920996147679-3.8857805861880E-15    1.59540682856021
         3    10.2957517115474-3.5527136788005E-15    1.49409343503715
*) The situation is even worse with OptiStruct. The output file (first three nodes) looks like this.
GRID           1        10.435290.375   1.696909
GRID           2        10.0921 0.0     1.595407
GRID           3        10.295750.0     1.494093
I don't want to create white space manually because the meshes I work with, in general, contain thousands of nodes. So, I need a proper solution for this issue. I am using the HyperWorks14.0 - student version.
Thanks,
Chenna.
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited September 2017
    Hello everyone,
    I think this is 'fixed format' of Optistruct. No spaces, no problem :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> because the reader will work on the length of input data.
    Have a look at Reference Guide:
  • Altair Forum User
    Altair Forum User
    Hi Chenna,
    As Nguyen-Dai told this is a fixed format. We suggest you to install Textpad and open the starter (_0000.rad) file in Textpad which shows better alignment of keywords and numbers.
    As a general note, for nodes in RADIOSS the format is as shown below.
    For more information please go through the Reference Guide of RADIOSS, which can be downloaded from  http://forum.altairhyperworks.com/index.php?/topic/20652-radioss-2017-reference-manual-documents-user-guide-and-tutorials/
  • Altair Forum User
    Altair Forum User
    edited November 2020
    Thank you Nguyen and George, for your answers.
    Unfortunately, they do not help my cause. I am using Hypermesh only to generate meshes for my in-house FEA code. So, the RADIOSS reader does not help me. I have to have the coordinate with some delimiter which I can process to be readable into my code.
    Textpad is my default text editor. I also opened the .rad files in Notepad, Wordpad and MS Word, and I didn't see any difference in the format. I have attached the file for your reference. Please not me know if I am doing something wrong.
    The only option I can think of now is to generate to an AWK script to break the coordinates.  I must say that this is very inconvenient. Please let me know if there is any other way around this.
  • tinh
    tinh Altair Community Member
    Hi , you can try this way
    - use optistruct profile
    - set up a temporary loadcase (just to run optistruct)
    - enter analysis > control cards> ECHO : this will make OS write out GRID, ELEMENT,.. to *.out file
    - export data to *.fem file
    - to activate comma delimiter when OS echo, open *.fem file and add line 'ECHOON PARSED' below the line 'ECHO'
    - save *.fem file and run OS, then open *.out file to copy data with comma delimiter
  • Q.Nguyen-Dai
    You have several posibilities:
    • Write you code to read 'fixed format' output of Optistruct. Also try 'long fixed format' yet?
    • Write yourself a FE output template to export the mesh directly into your in-house software format.
  • Altair Forum User
    Altair Forum User
    Thank you all for your answers.
    I did not like Tinh's solution because I do not like the idea of running a solver simply for the sake of obtaining a better format for the mesh data. It is cumbersome.
    @Nguyen, I could not figure out what 'fixed format' and 'long fixed format' are. I don't see them in v14.0.
    I solved my problem by
    1.) developing a simple awk script for the file generated using v14.0,
    2.) installing 2017 version in which Optistruct has 'free format' which exports the data in comma separated format which I can process easily.
    Thank you.
  • Q.Nguyen-Dai
    I found in my HW v14:
  • FaroukM
    FaroukM Altair Community Member
    edited June 2019
    Well there is actually 2 solutions :
    %% First one : Standard format. In this case the *fem file is written like
    GRID           NumOfNode        XCoordYCoordZCoord   % NB = XCoord, YCoord and ZCoord contain 8 characters, It's easy to write a code to separate all this things
    %% Second One : Long Format. In the second case, the *fem file can be read easily !!
    GRID*          NumOfNode             XCoord        YCoord
    *       ZCoord
    Cheers !
