I have a model where there is pretension in the bolts and hold down loads applied to the model. Then I want to run a modal analysis with these loads applied. How is it done in Optistruct? Is it done in two loadsteps? Also, as I have a linear static and well as a modal analysis to be done to the model, what solution card should be used?
