analysis results-element stresses in out file not showing
Altair Forum User
Altair Forum User
  Hi, I ran the optimization solver using optistruct with basic point loads as a test. However when i apply the display von mises stress on simple averaging method, there is nothing. It seems to be running fine with no errors so I don't understand whats happening. see picture attached<?xml version="1.0" encoding="UTF-8"?>safasgfsdg.png
 output file spit out this:
1 MaxDisp                  1240140    0.00000
   0    1 MaxStress                      0    0.00000
   0    2 MaxDisp                       60   0.282330E-01
   0    2 MaxStress                  31836   -496.786
   0    3 MaxDisp                     3886  -0.411211
   0    3 MaxStress                  32798    3767.72
   0    4 MaxDisp                       65  -0.137933
   0    4 MaxStress                  12682    1697.60
   0    5 MaxDisp                       65    0.00000
   0    5 MaxStress                  12682    0.00000
   0    6 MaxDisp                       63  -0.815247E-01
   0    6 MaxStress                  12682    754.470
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Have you tried without any averaging method?
    If you can you check whether HV displays contour without any averaging method?
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited June 2016
    Check for other stresses as well.Use clear contour & Click on play button.
