1, when I create a surface throught lines, sometimes the surface is not according exactly the lines. I do not konw why there is this small change. How can the edge of surfaces be exactly accroding to lines?
2, I checked also the instruction of command
*splinesurface entities mark plane_flag plane options
*surfacesplineonlinesloop mark_id fill_gaps use_surfs options
there are some options for this problem? Especailly for the option with Bit values, I do not know how to use it.
