im getting an error will running the model ie unstable rigid.i have change Ispher=1
what does these mean how can i fix this
Some things you should check:
1. All the Nodes should be properly connected, that means all slave nodes should be structural (or at least have some mass), masternode should be non-structural
2. set Isphere=1
3. Give a little additional mass (via Mass field entry)
