I only saw the binder forces in the results, but no force for Ram.
It is possible to stop the binder in the end of stroke? Sometimes i have less force on the binder and i need the end position fix.
Thanks a lot
Dear Georg,For check the tool force, when visualizing the results, press left click on the die component and check for the forces. You can convert the forces from Newton to Ton Force by pressing right click on the plot and select the convert force to ton force option.The die force shows the tools tonnage as it includes the forces for the bottom binder and bottom pad, but if using top pad or binder, then you can take the sum of both the tools (die and binder).And to manipulate the stroke, you can manipulate it from the edit tool position.Thanks and Regards,Saurabh
