Hi All
I am running small model of study of assembly steel tube (modeled with shell elements) into the Plastic part (modeled with Tetra elements).
Its Quasi static Non Linear problem, I have prescribed displacement to steel tube (via rigid) and defined contact between (Node to shell) Steel and plastic parts (Shell as master,Plastic part as Slave).
My model is taking lot of time to solve and analysis is not completing.
I have used below contact cards
$$ CONTACT Data
CONTACT 2 5 2 5 NORM2.0 NO
+ N2S
Attached is model i am trying to run.
Any help is much appreciated
Regards
Kash
