Can some one please help me with fixing the error? I am trying to supply heat flux inside the cylinder and outside it is convective BC with T amb of 0. But I am facing the following error ' *** See next message about line 2536 from file: G:/AM Optimization/AFRL Work/Intital Test/Initial cylinder test.fem 'CONV 12649 2 0' *** ERROR # 1000 *** in the input data: Incorrect data in field # 6.
Thanks,
Hi Darshan,
You need to provide the ambient temperature point which is missing in CONV card.
Hi Darshan, You need to provide the ambient temperature point which is missing in CONV card.
Can you describe more clearly, I had a same mistake. Thanks.
'CONV 8706 2 0' *** ERROR # 1000 *** in the input data: Incorrect data in field # 6.
Hi @Phat Vu
Please provide ambient temperature in your model.
