Hi everyone,
I'm trying to model a cylindrical section being held between a grip that tightens around it. When I look at each jaw however, I have a contact pressure concentration in one area and I can't seem to find out why. I'm using Optistruct V13 and I use the auto-contact tool to create the contacts between each component.
I have checked for penetration between these components and there is none (there is between two other pieces but I do not look at these).
I have quite a fine mesh as I'm looking at this specific area (mesh size 0.5mm). Does anyone know what I could do to get rid of this point? Could it be that these nodes are slightly irregular and 'sticking out' slightly from the component?
Thank you for any help you may be able to give me!
