Hi there,
    	I am using Simlab for over 2 years. So far I did not have problem with the import/translate of the file.
    	But now we started to use this software also here in Prague and the translate - Catia to Parasolid does not work. If I preread somewhere else and than reread it again, it works because there is this x_t file. Could you please help me, as what I should be doing? If we have license to use Simlab on Linux workstation, can we also run it on Windows?
Thank you in advance for your help.
    	Zbynek
