Analysis & Optimization don't start
Hi all;
I`m doing the combination tutorial (last one) from the list in the link http://www.altairhyperworks.in/edu/contest/aoc/2013/tutorials-and-downloads.html#.WeHKJGiCxPY and at step 9 when i`m trying to start the optimization nothing happening (at the down-left corner something running but it stops on 'Ready').
This is the first run i`m trying to do using a new computer i bought... Maybe it`s related to that...
Thanks;
Hi @Danny
Make sure you are saving the file name with .fem extension. For example when you are saving the file from OptiStruct panel>> Save as type in as <filename>.fem instead of <filename>
Please let us know if this helped.
0 -
i also tried doing the same but this error i got . can anyone plz help me out
0 -
Hi Rahul,
This is a know issue with HyperWorks 2017 and our devs are working on it.
There is a workaround for this. When you create a Frequency response DO NOT select the loadstep. Instead refer to loadstep when creating objective or dconstriant.
0 -
yes i got the result now. thanks
0 -
Thank you for the update /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
0 -
Altair Forum User said:
Hi @Danny
Hi Prakash
Thanks for your answer =]
I saved the file name as you suggested and still i`ve the same problem.
I tried to do another tutorial (Composited Monocoque optimization) and it did the same thing when i tried to run the analysis.
i`m also using HW2017.
Thanks.
0 -
Yeah sure.
The comp.hm model is the first model which made the problem (the reason i opened this thread).
02_analysis _complete.hm is the other one. I downloaded this model without changing it at all.
Thanks.
0 -
Hi @Danny
I am able to run the model without any issues.
Were you able to run the 02_analysis_complete.hm file?
0 -
Unfortunately no.
I tried to reinstall the software and it didn't work.
0 -
Hi Danny,
This could be the case if you are using a full suite of HyperWorks. Solvers may not be available on your machine and only HyperWorks Desktop (HM, HV, HG) are available.
Can you please check whether solvers are installed on your machine at all?
on HyperMesh Go to Help>>Update and System information. Copy the information and paste the same here.
0 -
Thanks for your help Prakash.
Apparently the problem caused because the files was located inside directories which was inside 'Program Files' directory. And it was on 'Read only'....
In order to run the analysis/optimization it should not be inside 'Read only' directories. =]
0 -
This is something I learned today /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Thank you, I hope now you are able to run the files.
0 -
Hey,
I am facing the same problem, it shows ready only and solver is not invoked.
As you asked for I have shared the results of 'update and system information'
Can you please help me with this?
Altair Forum User said:Hi Danny,
Altair Home: C:/Program Files/Altair/2019-edu
Updates Information:
No updatesVersions:
e_2019_win64.exe: 2019 (Feb 26 2019)
hmobj.dll: 2019.0.0.70 (Apr 15 2019)
hmopengl.exe: 2019.0.0.70 (Apr 15 2019)
hst.exe: 2019.0.0.70.1606541 (Apr 15 2019)
hstbatch.exe: 2019.0.0.70.1606541 (Apr 15 2019)
hvp.exe: 2019.0.0.70 (Apr 15 2019)
hw.exe: 2019.0.0.70 (Apr 15 2019)
hwmbdmodel.dll: 2019.0.0.70 (Apr 15 2019)
hwplot.dll: 2019.0.0.70 (Apr 15 2019)
hwpost.dll: 2019.0.0.70 (Apr 15 2019)
hwtext.dll: 2019.0.0.70 (Apr 15 2019)
hwvideo.dll: 2019.0.0.70 (Apr 15 2019)
hwx.exe: 2019.0.0.70 (Apr 15 2019)
nusolver.dll: 2019 (Mar 5 2019)
optistruct_2019_win64.exe: 2019 (Mar 20 2019)
templex.exe: 2019.0.0.70 (Apr 15 2019)0
