While doing mesh in AcuConsole i got some error. And it shows Error Msg as 'General Error' and Error code as '60'.
Tell me how to check this error description.
Regards
Ravi Harti.
These ones can be hard to detect. You can check for a file called meshsim.jou and see if it provides any more information on the cause of the error. If that doesn't provide any insight, I usually start turning off features (boundary layer mesh, etc.) until the error goes away. That can help to narrow the problem down.
Thanks for your reply.
I was also doing same things like turning off boundary features and varying relative or absolute mesh size. but it gave error code specifically that's why i thought there may be data base for specific error.
Ravi Harti
