hierarchy error
Please share the entire .out file to debug.
last problems shorted out but now it shows 'a. rst NOT FOUND ERROR TERMINATION'
Hi Pankaj,
Looks like you have not applied material to the components/elements or an incompatible material has been applied.
Please check the following at your end:
1) Check if PART card has been applied or not to the components.
2) check if property and material has been updated to the components.
now error comes script execution nf.rad file not suitable for both run
share the image of the error please.
sir plz explain means or file.rst not found error termination
Pankaj,
please share the entire error or .out file.
sir i unable to use dropbox....
and problem is that .rst file is not found error termination
sir now problem solved but no crash is shown and also no timestep found
now error is total mass error reached
use this link and upload the model files (both starter and engine file) https://ftam1.altair.com/filedrop/~Ce4god
how to solve hierarchy error?
Every component in RADIOSS should be assigned PART as card image ( this do not apply for RIGID elements).Kindly check for same & run.
Regards
Rahul R
